[Blockierte Grafik: http://farm4.static.flickr.com/3153/2851702652_8cc7cafdd5.jpg]
Attached is a copy of new price sheet for J's Racing prodcuts.
1) Effective Jun 01, 2012, most of the exhaust prices go up by €10 to €30.
2) Short antenna B has been discontinued.
3) Effective today, Special radiator RR prices go up but at the same time, more economical version - Max Cooling Radiator have been added to several models.
S 2000 Part Number Suggested Retail
Hyper single clutch kit JHH01SD-S1 EUR 1.808,00
Large capacity slave cylinder (for early model) PO-S1-100 EUR 272,00
Large capacity slave cylinder (for late model) PO-S1-200 EUR 272,00
Clutch direct line (for early model) DCL-S1-100 EUR 134,00
Clutch direct line (for late model) DCL-S1-200 EUR 170,00
LSD 1.5 way KLD-S1-15 EUR 1.252,00
LSD 2.0 way KLD-S1-20 EUR 1.252,00
Drive shaft spacer DSS-S1 EUR 286,00
Drive shaft spacer bolt set DSS-S1-BN EUR 65,00
Rigid differential mount RDM-S1 #WAARDE!
Final gear set 3.9 FG-S1-39 EUR 1.341,00
Final gear set 4.4 FG-S1-44
Final gear set 4.7 FG-S1-47
Final gear set 4.9 FG-S1-49
Final gear set 5.1 FG-S1-51
Final gear set w/ WPC PIP coating 3.9 FGW-S1-39 EUR 1.720,00
Final gear set w/ WPC PIP coating 4.4 FGW-S1-44
Final gear set w/ WPC PIP coating 4.7 FGW-S1-47
Final gear set w/ WPC PIP coating 4.9 FGW-S1-49
Final gear set w/ WPC PIP coating 5.1 FGW-S1-51
Reinforced ring gear bolt set KRG-S1 EUR 97,00
Differential magnetic drain bolt MDB-S1-D EUR 65,00
S2000 manual transmission magnetic drain bolt MDB-S1-MT EUR 26,00
S2000 differential distance collar DDC-S1-100 EUR 116,00
Shims for the differential collar 3.83mm to 4.09 mm EUR 13,00
15 Shims set DDC-S1-ALL EUR 180,00
Tsuchinoko intake system TCC-S1 EUR 1.326,00
Tsuchinoko intake system (for Type S bumper) TCC-S1-JS EUR 1.326,00
Air filter for S2000 Tsuchinoko intake AFT-S1 EUR 150,00
Max flow air filter MAF-S1-200 (AP1) EUR 186,00
Max flow air filter MAF-S2-200 (AP2) EUR 186,00
65 pai big throttle BSNT-S1 EUR 737,00
DBW 66,5 pai big throttle BSNT-S2 EUR 853,00
Big throttle modification BS-S1 EUR 380,00
Big throttle modification BS-S2 EUR 515,00
Carbon air duct for carbon hood type V AID-S1-V EUR 520,00
Carbon air duct for stock hood AID-S1-N EUR 520,00
Carbon air duct for type S bumper AID-S1-JSN EUR 412,00
Carbon air duct for stock hood, stock air box , & type S bumper AID-S1-JS EUR 412,00
Stainless header 4-2-1 with thermal wrap XA-S1-B EUR 1.886,00
Stainless header 4-2-1 XA-S1 EUR 1.633,00
Circuit converter (CAT killer) ZH-S1 EUR 279,00
Titanium Exhaust FX-PRO 60RS FTM-S1-60RS EUR 2.478,00
FTM-S1-60RS-EMS EUR 2.693,00
Titanium Exhaust FX-PRO 70RS FTM-S1-70RS EUR 2.750,00
Titanium Exhaust FX-PRO 70RR FTM-S1-70RR EUR 2.750,00
FTM-S1-70RR-EMS EUR 2.964,00
Titanium Exhaust FX-PRO 60RS Dual FTMW-S1-60RS EUR 3.185,00
Titanium Exhaust FX-PRO 70RS Dual FTMW-S1-70RS EUR 3.456,00
Inner silencer for Titanium exhaust IS-75 EUR 82,00
C304 SUS Exhaust 60RS C304-S1-60RS EUR 1.086,00
C304 SUS Exhaust 70RR C304-S1-70RR EUR 1.149,00
C304 SUS Exhaust 70RS C304-S1-70RS EUR 1.149,00
C304 SUS Exhaust 60RS Dual C304W-S1-60RS EUR 1.305,00
C304 SUS Exhaust 70RS Dual C304W-S1-70RS EUR 1.368,00
C304 SUS Exhaust 60RS EMS (EMS included) C304-S1-60RS-EMS EUR 1.249,00
C304 SUS Exhaust 70RR EMS (EMS included) C304-S1-70RR-EMS EUR 1.313,00
C304 SUS Exhaust 70RS EMS (EMS included) C304-S1-70RS-EMS EUR 1.313,00
C304 SUS Exhaust 60RS Dual EMS (EMS included) C304W-S1-60RS-EMS EUR 1.539,00
C304 SUS Exhaust 70RS Dual EMS (EMS included) C304W-S1-70RS-EMS EUR 1.582,00
Titanium single for Type GT aero 70RR GTFTM-S1-70RR EUR 3.576,00
Titanium dual for Type GT aero 70RS GTFTM-S1-70RSW EUR 3.605,00
C304 SUSsingle for Type GT aero 70RR GTC304-S1-70RR EUR 2.084,00
C304 SUS dual for Type GT aero 70RS GTC304-S1-70RSW EUR 2.113,00
Reinforced hangar bushing MKB-01 EUR 19,00
Reinforced hangar bushing B MKB-B EUR 22,00
S2000 Exhaust Bushing Set Dual MKB-S1-D EUR 86,00
S2000 Exhaust Bushing Set Single MKB-S1-S EUR 56,00
(New) Showa special damper kit w/ spring SSK-S1-SH #WAARDE!
Crux damper kit w/ pillow upper Damping set for street tire DSPL-S1-FTRP EUR 5.929,00
Front camber joint w/ roll center L1 +2 degree CAJ-S1-L1 EUR 524,00
Front camber joint w/ roll center L2 +3 degree CAJ-S1-L2 EUR 524,00
Front camber joint w/o roll center S1 +2 degree CAJ-S1-S1 EUR 383,00
Front camber joint w/o roll center S2 +3 degree CAJ-S1-S2 EUR 383,00
Roll center adjuster plate L1 S1 to L1 CAJ-S1-RPL1 EUR 144,00
Roll center adjuster plate L2 S2 to L2 CAJ-S1-RPL2 EUR 144,00
Camber joint ball joint replacement CAJ-S1-BJ EUR 93,00
Camber joint ball joint replacement CAJ-S1-GB2137 EUR 32,00
Rear roll center adjuster 12mm RCJ-S1-12 EUR 397,00
Rear roll center adjuster 20mm RCJ-S1-20 EUR 397,00
Roll center adjuster 12mm knuckle assy (left) RCJ2A-S1-12L EUR 899,00
Roll center adjuster 12mm knuckle assy (right) RCJ2A-S1-12R EUR 899,00
Roll center adjuster 20mm knuckle assy (left) RCJ2A-S1-20L EUR 899,00
Roll center adjuster 20mm knuckle assy (right) RCJ2A-S1-20R EUR 899,00
Wide tread spacer 10mm WRS-S1-10 EUR 202,00
Wide tread spacer 15mm WRS-S1-15 EUR 202,00
Wide tread spacer 26mm WRS-S1-26 EUR 227,00
Wide tread spacer 20mm WRS-S1-20 EUR 202,00
Long lug bolt 10mm LHB-S1-10 EUR 17,00
Long lug bolt 20mm LHB-S1-20 EUR 20,00
Rear hub ASSY with 10mm long lug bolt HA-S1-R10 EUR 182,00
Rear hub ASSY with 20mm long lug bolt HA-S1-R20 EUR 195,00
Front hub ASSY with 10mm long lug bolt HA-S1-F10 EUR 195,00
Front hub ASSY with 20mm long lug bolt HA-S1-F20 EUR 207,00
S-tai long lug bolt 15mm LHBSS-S1-15 EUR 34,00
S-tai HQI rear hub KHA-S1-R EUR 316,00
S-tai HQI front hub KHA-S1-F EUR 316,00
S-TAI High Frequency Waved Front Hub ASSY with SPL Long Hub Bolts KHASS-S1-F EUR 451,00
S-TAI High Frequency Waved Rear Hub ASSY with SPL Long Hub Bolts KHASS-S1-R EUR 451,00
Pillow rear control arm CAM-S1 EUR 658,00
(anti- bump steer)
Pillow tie rod end set (anti-bump steer) PTE-S1 EUR 480,00
Engine torque damper (left side steerng wheel) ETD-S1-SL EUR 293,00
Engine torque damper & towerbar ETD-S1-TL EUR 505,00
Heat Protector for Engine Torque Damper ETA-S1 EUR 123,00
Front aluminum tower bar standard TB-S1-F EUR 285,00
Rear aluminum tower bar TB-S1-R EUR 285,00
Rear lower arm bar RRB-S1 EUR 207,00
Front aluminum tower bar for torque damper TB-S1-FE EUR 298,00
Side inner fender brace SIB-S1 EUR 330,00
Upper arm reinforcement HUA-S1 EUR 706,00
Reinforced front sub frame HSF-S1-F EUR 1.285,00
Reinforced rear sub frame HSF-S1-R EUR 2.238,00
