Im offering here complete Turbo engine with the power:
 341,3 WHP @ 6603RPM, 398 Nm @ 5642 RPM (wheel horse power)
Now the engine is prepare for rebuild. Im really noob, I drove the car with open filling oil cap and the engine blow on all cylinders :((((( The ECU AEM is remapped, the engine drive perfect. I have dyno test result.
So the engine must be new bored, honed and assembly.
The works and parts what you should need:
 - new oversize pistons +0,5mm
 - new bearings (ACL)
 - repased turbocharger (just bearings)
 - new head gaskets
 - rebored the zylinders
 - rehoned the zylinders
 - assembly the engine
The reason of sell, I bought GT-R R35
DYNO RESULTS:
 - 341,3 WHP @ 6603RPM, 398 Nm @ 5642 RPM (wheel horse power)
 - 403 HP @ 6603RPM, ? @ 5642 RPM (flywheel horse power)
ENGINE:
 - Powered by RRR POWER, dyno test (254KW/341,3WHP @ 6603RPM, 398Nm @ 5642rpm, ? PSI)
 - 2.0 DOHC 16V VTEC I-4 F20C (stock 177KW/240PS @ 8300rpm, 208Nm @ 7500rpm) – MY 2003
 - REV HARD turbo kit stage 2
Block:
 - AEBS T-sleeves engine work
 - CP forged pistons 9:1 w/ rings (bore: 88mm)
 - CARRILLO forged rods
 - ARP head studs
 - ARP rod bolts
 - ACL rods bearings
 - ACL main bearings
 - ACL thrust bearings
 - High volume race oil pump
Head:
 - FERREA competion plus stainless steel valves
 - FERREA dual springs
 - FERREA titanium retainers
 - FERREA valve locators
 - COMETIC head gasket .040 / 1mm thick C4335-040
Boost:
 - Turbo T3/T04E hybrid 0.60AR compressor, 0.63AR exhaust
 - REV HARD cast iron manifold
 - TIAL 35mm wastegate
 - VORTECH blow off valve (BOV)
 - AEM 3.5bar MAP Sensor kit 30-2130-50 w/ adapter on TB
Fuel &ignition:
 - AEM EMS standalone 30-1052U w/ UEGO controller
 - NGK IRIDIUM BKR8IEX spark plugs (one step colder)
 - RC 750cc saturated injectors w/ clips and spacers
 - AEM fuel pressure regulator
 - WALBRO high volume intank fuel pump 255lh
 - SYTEC fuel pressure gauge on fuel rail
Cooling:
 - PIPERCROSS PX700 air filter 3”
- PIPERCROSS mini breather filter
 - KOYO aluminum radiator 53mm
 - KOYO radiator cap 1.3bar
 - SPOON thermostat (low temp)
 - MUGEN fan switch (low temp)
 - Custom carbon air box
 - LAMINOVA C43 365mm water oil cooler
 - MOCAL oil filter adapter with thermostat
 - P2R thermal throttle body gasket
 - P2R thermal intake manifold gasket
 - SPEARCO intercooler 27” x 6.5” x 3” (polished)
 - Chromed IC 2,25” aluminized mandrel bent piping
 - SAMCO intercooler silicone hoses (blue)
 - SAMCO radiator silicone hoses (blue)
 - SAMCO air filter hoses (blue)
 - SAMCO vacuum hoses (blue)
 - Big stainless steel T-clamps
Others:
 - DEI turbo insulation cover
 - THERMOTEC express sleeve on wiring and hoses
 - THERMOTEC thermo sleeve on wiring and hoses
 - THERMOTEC micro louver air shield (between battery and headers)
 - POWER ENTERPRISE Mag Power II oil filter 04A (magnetic)
 - CUSCO oil catch tank
 - JS RACING magnetic bolt
 - Relocation oil kit w/ D-10 stainel steel lines
 - Stainless steel oil lines D-10 + fittings
 - R1 WURKS alternator light weight pulley
 - Krank vents
 - AEM A/F ratio gauge type wideband UEGO controller 30-4100
 - AEM boost display gauge 30-4406
 - AEM serial datastream gauge (19 channel) 30-4300
 - AEM oil pressure display gauge 30-4407
 - AEM oil temperature display gauge 30-4402
 - AEM water temperature display gauge 30-4402
 - AEM EGT sensor kit 30-2050
 - AEM air inlet temperature kit 30-2010
 - New OEM water oil pump
 - New OEM ignition coil packs
 - New OEM sensors
 - Blocked recuperation of exhaust Gates
Engine styling:
 - Polished intake manifold
 - White color valve cover
 - Polished injectors cover
 - Aluminium oil cap
EXHAUST:
 - Custom downpipe 3” stainless steel (polished)
 - ULTIMATE RACING 3” high-flow stainless steel catalytic converter
 - ULTIMATE RACING 3” stainless steel exhaust catback w/ AP2 OEM tips (polished)
 - THERMOTEC exhaust header wrap on downpipe w/ snap straps
All parts costs really a lot of money. Just reamapped costed 1500 EUR on dyno.
Everything is prepare beat up without problem 400PS. With other turbocharger is no problem 500PS and more.
I imagine the price 10.000 EUR for all these parts. The NP was 3-4x higher.
Or I can sell it on the parts. Just PM me.
