Many many parts tuning/performance + OEM
  • - Solid pillow ball Top mount CUSCO – NEW UNUSED - 130 EUR
    - Carbon hardtop SEIBON style with install parts. Great condition without damages/cracks + stand + OEM cover – 2000 EUR complete. Perfect fit.
    - SSR PROFESSOR SP-1 flat black w/ polished lip (front 8x18 ET49, rear 9,5x18 ET55 + BF GOODRICH tires (front 225/40/18, rear 255/35/18) + BLOX forged lug nuts – alu/mag alloy (black) – 1400 EUR – perfect condition, without cracks or damages
    - RevHard downpipe 63mm for turbo T3/T4 mm + 35mm external WG – 100EUR
    - AEM A/F ratio gauge type wideband UEGO controller 30-4100 – 130 EUR – very good condition, original box
    - AEM boost display gauge 30-4406 – 100 EUR - very good condition, original box
    - AEM serial datastream gauge (19 channel) 30-4300 – 120 EUR - very good condition, original box
    - AEM oil pressure display gauge 30-4407 – 120 EUR - very good condition, original box
    - AEM oil temperature display gauge 30-4402 – 100 EUR - very good condition, original box
    - AEM water temperature display gauge 30-4402 - 100 EUR - very good condition, original box
    - AEM EGT sensor kit 30-2050 – 75 EUR - very good condition, original box
    - AEM air inlet temperature kit 30-2010 – 40 EUR - very good condition, original box
    - A-pillar Gauges holder AUTOMETER for 2x 52mm – 50 EUR
    - NRG boss kit like new – 75 EUR – like new, original box
    - Original Honda part - seat back pocket with S2000 logo – 25 EUR – like new, with instruction
    - VISION batterry holder blue – 15 EUR – perfect condition
    - SKUNK2 VTEC cover black – 20 EUR – new in box
    - JS RACING oil sump magnetic bolt – 15 EUR
    - MCGARD lug nuts – 20 EUR – with original box
    - WALBRO high volume intank fuel pump255lh + complete volume level and holder – 150 EUR - only 500km
    - Mishimoto lightweight radiator stay black (2pcs) – 10EUR
    - LAMINOVA C43 365mm water oil cooler with stands on S2000 (AN10 outs) – 350 EUR – very good condition
    - Samco silicone radiator hoses with water temp adaptor (gold) – 80 EUR
    - CUSCO Oil catch tank with blue SAMCO hoses and holder for S2000 – 70 EUR
    - AEM EMS standalone 30-1052U w/ UEGO controller – 900 EUR –perfect condition
    - Turbokit Revhard Stage 2 – manifold, Turbo T3/T4 (defect, repair costs aprx 400 EUR), DEI titan turbo cover, stainless steel 76mm custom downpipe with thermotec wrap, TIAL 35mm wastegate, intercooler SPEARCO + chrome pipes + Samco silicone hoses, blow off valve Vortech, oil lines, oil relocation kit – 2300 EUR – parts have good condition
    - Ultimate Racing 200CPSI 76mm sport cat – 175 EUR
    - Pipercross PX filter 76mm – 50 EUR
    - MOCAL oil filter adapter with thermostat AN10 outs + M20 center bolt – 40 EUR
    - P2R thermal throttle body gasket – 10 EUR
    - P2R thermal intake manifold gasket – 15 EUR
    - 4x NGK IRIDIUM BKR8IEX spark plugs (one step colder) – 60 EUR
    - 4x RC 750cc saturated injectors w/ clips and spacers – 225EUR – great condition
    - AEM fuel pressure regulator – 80 EUR
    - KMS High volume race oil pump – only 65000km - 150 EUR
    - SPOON thermostat (low temp) – 40 EUR – only 6500km – great condition
    - MUGEN fan switch (low temp) – 40 EUR – only 6500km – great condition
    - Crank vents – Pipercross breather filter + polished aluminium injcetors covers – 130 EUR
    - Real carbon fiber custom air box for turbo swap – 120 EUR
    - Complete zylinder head with – 2500 EUR
    - FERREA competion plus stainless steel valves
    - FERREA dual springs
    - FERREA titanium retainers
    - FERREA valve locators
    - OEM cams 6500km
    - Blocked recuperation of exhaust Gates for intake manifold - 20 EUR
    - OEM Polished intake manifold – 300EUR
    - OEM thorttle body + TPS sensor – 125 EUR
    - AEM 3.5bar MAP sensor kit 30-2130-50 w/ adapter on TB – 85 EUR
    - CARRILLO forged rods ARP rod bolts – 600 EUR
    - OEM ALTERNATOR + R1 WURKS alternator light weight pulley – 125 EUR
    - Engine block with AEBS sleeves, must be new bored + ARP head studs – 750EUR
    - OEM crank, perfect condition – only 6500km – 600 EUR
    - OEM engine holders L + P – 40 EUR each
    - OEM starter – like new – only 6500km – 90 EUR
    - OEM ignition coils – only 6500km – 80 EUR each – 250 EUR all
    - OEM front light washers for facelift model 04+ - 70 EUR
    - OEM Valve cover 04+ with solid PVC valve – great condition – 120 EUR
    - OEM dampers + lower springs – 125EUR
    - OEM front brake calipers L+R – 150 EUR
    - Engine block with cracked zylinder walls without other parts – just block + crank holder – 300 EUR
    - OEM differntial with defect bearings, diferential, crownwheel + final gear are OK, complete with cover etc. – 225 EUR
    - OEM water oil pump – only 6500km – 100EUR
    - Many OEM sensors – only 6500km
    - White color valve cover, ready for repaint – 100 EUR
    - Aluminium oil cap red – 10 EUR
    - MUGEN gas cap cover – 40 EUR
    PM me your email, I will send you the photos.
    If you take more parts, I will gibe the discount.
    I live in Prague, but I can send the parts with courrier DPD. Collection is possible.
    s2k@wm.cz
    +420 777271126
    Martin
