- Solid pillow ball Top mount CUSCO – NEW UNUSED - 130 EUR
- Carbon hardtop SEIBON style with install parts. Great condition without damages/cracks + stand + OEM cover – 2000 EUR complete. Perfect fit.
- SSR PROFESSOR SP-1 flat black w/ polished lip (front 8x18 ET49, rear 9,5x18 ET55 + BF GOODRICH tires (front 225/40/18, rear 255/35/1cool + BLOX forged lug nuts – alu/mag alloy (black) – 1400 EUR – perfect condition, without cracks or damages
- RevHard downpipe 63mm for Turbo T3/T4 mm + 35mm external WG – 100EUR
- AEM serial datastream gauge (19 channel) 30-4300 – 120 EUR - very good condition, original box
- AEM oil pressure display gauge 30-4407 – 120 EUR - very good condition, original box
- AEM oil temperature display gauge 30-4402 – 100 EUR - very good condition, original box
- AEM water temperature display gauge 30-4402 - 100 EUR - very good condition, original box
- AEM EGT sensor kit 30-2050 – 75 EUR - very good condition, original box
- AEM air inlet temperature kit 30-2010 – 40 EUR - very good condition, original box
- A-pillar Gauges holder AUTOMETER for 2x 52mm – 50 EUR
- NRG boss kit like new – 75 EUR – like new, original box
- Original HONDA part - seat back pocket with S2000 logo – 25 EUR – like new, with instruction
- VISION batterry holder blue – 15 EUR – perfect condition
- SKUNK2 VTEC cover black – 20 EUR – new in box
- JS RACING oil sump magnetic bolt – 15 EUR
- MCGARD lug nuts – 20 EUR – with original box
- Mishimoto lightweight radiator stay black (2pcs) – 10EUR
- LAMINOVA C43 365mm water oil cooler with stands on S2000 (AN10 outs) – 350 EUR – very good condition
- Samco silicone radiator hoses with water temp adaptor (gold) – 80 EUR
- CUSCO Oil catch tank with blue SAMCO hoses and holder for S2000 – 70 EUR
- AEM EMS standalone 30-1052U w/ UEGO controller – 900 EUR –perfect condition
- MOCAL oil filter adapter with thermostat AN10 outs + M20 center bolt – 40 EUR
- P2R thermal throttle body gasket – 10 EUR
- P2R thermal intake manifold gasket – 15 EUR
- 4x NGK IRIDIUM BKR8IEX spark plugs (one step colder) – 60 EUR
- 4x RC 750cc saturated injectors w/ clips and spacers – 225EUR – great condition
- AEM fuel pressure regulator – 80 EUR
- KMS High volume race oil pump – only 65000km - 150 EUR
- SPOON thermostat (low temp) – 40 EUR – only 6500km – great condition
- MUGEN fan switch (low temp) – 40 EUR – only 6500km – great condition
- Crank vents – Pipercross breather filter + polished aluminium injcetors covers – 130 EUR
- Real carbon fiber custom air box for turbo swap – 120 EUR
- Complete zylinder head with – 2500 EUR
* FERREA competion plus stainless steel valves
* FERREA dual springs
* FERREA titanium retainers
* FERREA valve locators
* OEM cams 6500km
- Blocked recuperation of exhaust Gates for intake manifold - 20 EUR
- OEM Polished intake manifold – 300EUR
- OEM thorttle body + TPS sensor – 125 EUR
- AEM 3.5bar MAP Sensor kit 30-2130-50 w/ adapter on TB – 85 EUR
- CARRILLO forged rods ARP rod bolts – 600 EUR
- OEM ALTERNATOR + R1 WURKS alternator light weight pulley – 125 EUR
- Engine block with AEBS sleeves, must be new bored + ARP head studs – 750EUR
- OEM crank, perfect condition – only 6500km – 600 EUR
- OEM engine holders L + P – 40 EUR each
- OEM starter – like new – only 6500km – 90 EUR
- OEM ignition coils – only 6500km – 80 EUR each – 250 EUR all
- OEM front light washers for facelift model 04+ - 70 EUR
- OEM Valve cover 04+ with solid PVC valve – great condition – 120 EUR
- OEM dampers + lower springs – 125EUR
- OEM front brake calipers L+R – 150 EUR
- Engine block with cracked zylinder walls without other parts – just block + crank holder – 300 EUR
- OEM differntial with defect bearings, diferential, crownwheel + final gear are OK, complete with cover etc. – 225 EUR
- OEM water oil pump – only 6500km – 100EUR
- Many OEM sensors – only 6500km
- White color valve cover, ready for repaint – 100 EUR
- Aluminium oil cap red – 10 EUR
- MUGEN gas cap cover – 40 EUR
PM me your email, I will send you the photos.
If you take more parts, I will gibe the discount.
I live in Prague, but I can send the parts with courrier DPD. Collection is possible.
s2k@wm.cz
+420 777271126
Martin
