- Solid pillow ball Top mount CUSCO – NEW UNUSED - 100 EUR
- RevHard downpipe 63mm for turbo T3/T4 mm + 35mm external WG – 100EUR
- AEM oil pressure display gauge 30-4407 – 120 EUR - very good condition, original box
- AEM oil/water/tranny temperature display gauge 30-4402 – 100 EUR - very good condition, original box
- AEM oil/water/tranny temperature display gauge 30-4402 - 100 EUR - very good condition, original box
- AEM EGT sensor kit 30-2050 – 75 EUR - very good condition, original box
- AEM air inlet temperature kit 30-2010 – 40 EUR - very good condition, original box
- A-pillar Gauges holder AUTOMETER for 2x 52mm – 50 EUR
- NRG boss kit like new – 70 EUR – like new, original box
- Original Honda part - seat back pocket with S2000 logo – 25 EUR – like new, with instructions
- VISION batterry holder blue – 15 EUR – perfect condition
- SKUNK2 VTEC cover black – 20 EUR – new in box
- MCGARD lug nuts – 20 EUR – with original box
- LAMINOVA C43 365mm water oil cooler with stands on S2000 (AN10 outs) – 350 EUR – very good condition
- Water temp adaptor (gold) – 8 EUR
- CUSCO Oil catch tank with blue SAMCO hoses and holder for S2000 – 70 EUR
- 4x NGK IRIDIUM BKR8IEX spark plugs (one step colder) – 60 EUR
- 4x RC 750cc saturated injectors w/ clips and spacers – 225EUR – great condition
- AEM fuel pressure regulator – 80 EUR
- KMS High volume race oil pump – only 6500km - 150 EUR
- MUGEN fan switch (low temp) – 40 EUR – only 6500km – great condition
- Crank vents – Pipercross breather filter + polished aluminium injcetors covers – 100 EUR
- Real carbon fiber custom air box for turbo swap – 120 EUR
- Blocked recuperation of exhaust Gates for intake manifold - 20 EUR
- OEM Polished intake manifold – 275EUR
- OEM thorttle body + TPS sensor – 125 EUR
- AEM 3.5bar MAP sensor kit 30-2130-50 w/ adapter on TB – 85 EUR
- CARRILLO forged rods + ARP2000 rod bolts – 500 EUR
- OEM ALTERNATOR + R1 WURKS alternator light weight pulley – 125 EUR
- Engine block with AEBS sleeves, must be new bored and honed + ARP head studs – 750EUR
- OEM engine holders L + P – 35 EUR each
- OEM starter – like new – only 6500km – 80 EUR
- OEM ignition coils – only 6500km – 80 EUR each – 250 EUR all
- OEM front light washers for facelift model 04+ - 70 EUR
- OEM dampers + lower springs – 100EUR
- OEM front brake calipers L+R – 150 EUR
- OEM engine block with cracked zylinder walls without other parts – just block + crank holder – 300 EUR
- OEM differntial with defect bearings, diferential, crownwheel + final gear are OK, complete with cover etc. – 200 EUR
- OEM water oil pump – only 6500km – 90EUR
- Many OEM sensors – only 6500km – price VB
- White color valve cover, ready for repaint – 100 EUR
- Aluminium oil cap red – 10 EUR
- MUGEN gas cap cover – 40 EUR
PM me your email, I will send you the photos.
If you take more parts, I will you give the discount.
I live in Prague, but I can send the parts with courrier DPD. Collection is possible.
s2k@wm.cz
+420 777271126
Martin
