Hallo Allen!
Wenn ihr da kein probleme mit haben schreibe ich das folgendes in English, weil mein Deutsch nicht super ist ![]()
First a short introduction!
My name is Wouter Vallen, founder and owner of Infinity Performance in Holland. We're specialised in mainly Toyota MR2's. But we can supply all the parts created in Japan or parts made all over the world for our japanese cars, like Berk Technology parts. We are located in the south of Holland in a city called Roermond, only 5 minutes away from the German border. (Nähe Monchengladbach, Köln, Aachen etc.)
Lately we get a lot of requests for S2k parts from all of Europe. Mainly Berk Technology parts. Of course we would like to help everyone out, but it saves us and the customers a lot when we can ship everything together instead of one by one ![]()
On to the Berk parts!
BT1601 Honda S2000 00-07 Cat Delete Pipe w/ Built in O2 CEL Fix
Large diameter 63.5mm piping (2.5in), full 304SS, & built in CEL fix. Includes new gasket & hardware. 06-07 S2000 with drive by wire have high incidents of CEL. 00-05 S2000's are 98% CEL free.
[Blockierte Grafik: http://img6.imageshack.us/img6/6646/bt1601.jpg]
Price Normal € 115,- Now € 99,-
Link: http://www.infinityperformance.nl/shop/product.php?prod_id=400
BT1601-HFC-MET Honda S2000 00-07 High Flow Catalytic Converter, OBDII Compliant
Featuring Magnaflow's new metallic substrate core. Less weight, more durability, and higher flow than your standard ceramic subsrtrate "high flow cat". Do not confuse these with cheap Chinese made ceramic substrate versions! These are very high quality parts made proudly in the USA by our expert fabricators.
Our test data shows that this cat flows 87% as well as a test pipe vs. 43% for the OEM Cat. Smog legal, high flow, no test pipe smell. You can have the best of both worlds.
[Blockierte Grafik: http://img3.imageshack.us/img3/5712/bt1601hfc.jpg]
Price Normal: € 199,- Now: € 179,-
Link:
BT1615 Honda S2000 00-07 50mm Exhaust Manifold/Header
Thermal barrier coated using High Performance Coatings (HPC) Hipercoat 1600+ process on the inside and outside of the header. The Hipercoat process helps maintain high exhaust gas velocity which is key in header design and ultimate power production. One of the few 304 stainless & inside/outside ceramic coated headers in the world. Uses large port 50mm primaries & high flow CAD designed 63.5mm collector (2.5"). Perfect compliment to the Berk Technology 2.5" test pipe. Includes secondary wideband O2 sensor port for fuel tuning. One of the best performing headers for the AP1 & AP2 S2000 at any price.
[Blockierte Grafik: http://img3.imageshack.us/img3/6352/bt1615.jpg]
BT1615 Non-Thermal Coated Stainless Steel Normal: € 399,- Now € 359,-
BT1615 HPC Ceramic Coated 304 Stainless Steel Normal: € 479,- Now € 439,-
link: http://www.infinityperformance.nl/shop/product.php?prod_id=402
Honda S2000 00-08 UHV Dual 57mm Titanium Exhaust
A proven 8 HP to the wheel
The exhaust uses an all new design that has yet to be seen for the S2000. Instead of using a single 80mm exhaust which would be ridiculously loud, we use twin 57mm pipes which greatly quiets down the exhaust. It is by no means a quiet exhaust like the J's 60rs, but if you can handle the sound volume of a 70mm single, you can handle the sound from our dual 57mm.
Specs:
• Dual 57mm tubing
• Dual Full Titanium Mufflers (not just the tips!)
• Full 304 Stainless Steel tubing & flanges
• Flows the same as a single 80mm exhaust
• Over Twice the velocity of a single 80mm
• Roughly 6db quieter than an 80mm single (4x quieter)
• Entire exhaust system weighs 26lbs (stock is 49lbs)
• Made in the US
Price € ASK
link: http://www.infinityperformance.nl/shop/product.php?prod_id=379
Honda S2000 00-08 70mm Cat Delete Pipe w/ Built in O2 CEL Fix
A full 70mm for the serious street/track S2000
Large diameter 70mm piping (2.75in), full 304SS, & built in CEL fix. Includes new gasket & hardware. Perfect for forced induction and high power NA applications. 06-07 S2000 with drive by wire have high incidents of CEL. 00-05 S2000's are 98% CEL free. Full high grade 304 stainless steel tubing and flanges!
Link:
[Blockierte Grafik: http://img6.imageshack.us/img6/9436/bt1602.jpg]
BT1602 Price Normal: € 129,- Now € 105,-
BT1602-HPC-MET Price Normal: € 219,- Now € 199,-
link: http://www.infinityperformance.nl/shop/product.php?prod_id=404
Link: http://www.infinityperformance.nl/shop/product.php?prod_id=401
GROUPBUY ENDS NEXT WEEK FRIDAY 17TH OF JULY
Thank you for looking!
With kind regards,
Wouter Vallen & Harm Koks
email: sales@infinityperformance.nl
Website: https://s2k.de/www.infinityperformance.nl
