TOP Gewindefahrwerk JIC MAGIC FLT-A1. Nur 6.000km gefahren, nuewertigen Zustand.
The JIC Magic FLT-A1 is a coilover suspension kit designed for the enthusiast who will drive on a daily basis and occasionally on the track. The JIC Magic FLT-A1 coilover kit features a 10 way adjustable damper. For strength, strut-type suspensions feature a wide shaft while multi-link type suspensions feature the smaller shaft damper. Most JIC Magic FLT-A1 coilover kits include front pillow ball upper mounts and front adjustable camber plates. Also included are springs of the linear-type for laser precision handling and adjustable lower brackets for ride height adjustments that do not affect damper travel.
Features:
- Adjustable Damper: Available for all applications with 10 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec.
- Cool Bend Linear Spring: Linear rate spring manufactured using chrome silicon metal alloy with cool bend process.
- High Tech Twin Tube Damper: The twin tube dampers utilize different sized shafts. Because strut-type suspension require more strength for support, a wider shaft is the damper of choice while the narrower shaft is more suited for multi-link / double wishbone suspension.
- Height Adjustable Lower Bracket: Adjustable height aluminum CNC machine-built bracket for double wishbone or multilink suspension.
- Adjustable Pillow Ball Uppermount: Included for all vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems.
* Some applications may come with a Rubber Bushing upper mount instead of an Upper Pillow Ball Mount.
Reference: JIC Magic FLT-A1 High Performance Coilover System, JIC Magic FLT - A1 Coilover System, JIC Magic FLT-A1 damper kit, JIC coilover kit, JIC damper kit, JICMagic coilover kit, FLT-A1 coilover kit
NP 1750 EUR. JETZT 1000 EUR.
