Science Of speed Fuel Surge system / AEM 320LPH pumpe.
Ideal voor Turbo oder Circuit / nurburging fährer!
fuel starvation:
The factory fuel tank is not designed for high lateral G force caused during cornering, especially with race compound tires. It is a common problem found on the S2000 caused especially during left hand corners where the fuel pump's pick up point, even with more than a half tank of fuel, can run dry, causing the fuel system to aerate and lose pressure. This has lead to engine damage caused by lean fuel conditions.
The ScienceofSpeed fuel surge tank can supply 30-60 seconds of fuel to the engine, even with complete loss of fuel flow from the fuel tank. The system works by utilizing the in-tank pump to supply fuel to a reservoir surge tank. This surge tank contains one or two pumps (depending on power requirements) which then supplies fuel to the engine. The surge tank operates independently of the fuel tank such that a buffer of fuel is available to the engine should the tank pick up run dry.
[Blockierte Grafik: http://www.scienceofspeed.com/products/engine_performance_products/S2000/ScienceofSpeed/fuel_surge_tank/surge_animation.gif]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/sos4_zps45106136.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/sos9_zpsf8f1508a.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/036490CD-69D6-4CEE-8EA5-70D3A46F2CBA_zpsjmvgkbca.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/ss11_zpsf9a90d1e.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/ss12_zps2b0930cc.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/ss20_zps9266c15d.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/ss19_zps5065f91b.jpg]
[Blockierte Grafik: http://i103.photobucket.com/albums/m157/Nyther713/ss18_zps39a108a2.jpg]
Plug N PLAY!
nür 2 monate alt!
verkauf wegens verkauf auto/turbo etc.
ASKING € 450,-
