Wir haben ein angebot empfangen von Herr Umemoto, dieser originale J's Racing S2000.
J'S RACING F22C COMP Engine ASSY SPEC-3
Capacity:2157cc, Bore*Stroke:87.0, Compression:12.7
Target Spec: 280ps/28kg
J'S RACING F22C COMP Engine Basic Menu
Cilynder Clean Up/Conrod and Piston Weight Caluculation
Valve Sheet Cut/Valve Fixing/ Metal Fixing
High Flow Port Modifi/All Parts Clean Up
J'S RACING SPL Oil Pan
J'S RACING Reinforced Valve Spring
AP1 Hyper ECU (Air Pump Cancel Option)
AP1 Big Throttle Body NTS
NGK Racing Spark Plug #9
S2000 SPL Oil Catch Tank
S2000 Alminium SPL Radiator RR
S2000 SAMCO Radiator Hose Kit
S2000 Low Temp Thermostat
S2000 Low Temp Thermo Switch
SPL Forcing Fan Switch
BILLION Racing Water ZERO
AP1 Titanium Exhaust System 70RS Blue
S2000 4-2-1SUS Exhaust Manifold with Thermo Bandage
S2000 SUS De-Cat Pipe
S2000 Tsuchinoko Air Intake Kit Carbon
S2000 FCR Slotted Brake Rotor Set
S2000 Rear Slotted Brake Rotor
AP1 Brake Line System ST
SEIDOYA F/R N1-500 Brake Pad
S2000 EXEDY Hyper Single Cluch Set
AP1 1.5way LSD
S2000 4.3 Final Gear Set
S2000 SPL Sleeve Cilynder
S2000 SPLDiff Distance Collar
S2000 SPL Shock Absorber Kit CRUX ver
For Semi Racing Tyre, 30click Adjust
F/R Bestex 18Kg Spring
J'S RACING Pillow Upper Mounting
S2000 Camber Joint L2
S2000 Roll Center Adjuster 20mm
S2000 Pillow Tie Rod End
S2000 Pillow Rear Contorol Arm
S2000 Drive Shaft Spacer
S2000 S-TAI High Frequency Waved Rear Hub ASSY
S2000 Engine Torque Damper with Tower Bar
S2000 Heat Protector for Engine Torque Damper
S2000 Upper Arm Gazette
S2000 SPL Rear Reinforced Sub Flame ASSY
Callosse 40Æ Chromoly Roll Gage 4+M+Arch Bar 7P
AP1/2 Ventilated Bonnet Type-V Carbon
S2000 Carbon Trunk Hood
S2000 Twin Canards for Genuine Bumper
S2000 3D GT-WING TYPE-2 WET Carbon
S2000 Carbon Radiator Cooling Plate Pre Cut Model
Titanium Shift Knob Blue
TECHTOM Compact Multi Monitor
RECARO SP-GT2 Black
RECARO Ultra Low Position Base Flame Right
TAKATA 4point Full Harness
RAYS CE28N 10 Spoke Gun-Metalic
BRIDGESTONE RE-11
[Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/IMGP3468.jpg]
[Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/IMGP3473.jpg]
[Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/IMGP3471.jpg]
[Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/IMGP3470.jpg]
[Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/IMGP3469.jpg]
€36500,00 mit Holländische Kennzeichen
