ZitatA popular alternative for people looking for an alternative tyre with better wet weather characteristics are now using Toyo Proxes
Tyre Sizes are as follows, please note that the rear Bridgestone ES02JZ had very narrow rainchannels, and if you are changing to a different brand, it is recommended that you consider adjusting the size to the one below.
Any other Tyre brand or model:
Front 205/55/ R16
Rear 245/45/ R16
was ist davon zu halten?
laut den technical faq auf s2ki.com kann man anstelle der 225er hinten auch 245er aufziehen, denkt ihr dass das ok ist bei den Serienfelgen?
