Das erste Easter Egg *) in einem Auto...
  • *) Easter Egg:
    Undokumentierte Funktion, sehr verbreitet bei Computer-Programmen oder in Form von Hidden Features auf DVDs Rolling
    There's a cheat code in the software running the BMW M3's sequential manual gearbox (SMG): Press the right buttons in the right order and the car will launch you from a stop after revving the engine to 5,000 rpm. But don't look for a how-to in the owners' manual—this feature is undocumented, an inside joke of sorts.
    To our knowledge, it's also the first automotive Easter egg, though—with increased reliance on computers—it would seem just a matter of time before they become standard fare, much like the hidden features in PC games and DVD movies. In the M3's case, there's also good reason for it: The SMG transmission is completely electronic, so you can't rev the engine and drop the clutch for tire-smoking acceleration—something the owner of a performance sedan just might want to do occasionally.
    But there is a catch. In Europe, where the feature isn't so hush-hush, doing more than 15 launches voids the car's warranty. Federal laws prohibit such stipulations here, so BMW has turned down the wick. U.S.-spec cars are programmed to wind to only 2,500 rpm—and our test car topped off at 1,800. That's why you have to ask your dealer to install the European software. Most will happily oblige.
    For lucky drivers of this hot car, here's how: Switch off the stability system and select shift program six. Switch the engine to sport mode. With the hand shifter in drive, hold it in the downshift position and press the gas pedal. The engine will rev to the preprogrammed rpm and hold. Now release the shifter. The car will launch forward violently and the engine's revs will climb quickly, so be prepared to upshift.
    Quelle:
    http://www.popsci.com/popsci/auto/article/0,12543,358540,00. html
  • Is kein Easter Egg
    Nennt sich Startautomatik...
    und ist eigentlich in EU bekannt...
    vielleicht traut BMW den Amis die Verwendung von so einem feature nicht zu :D:D:D
    LG Michi
  • Das einsetzen der Launchcontrol führt zu einem erlischen der Garantie... Shocked (Wird jedes mal im Steuergerät gespeichert)
    Das sollte auch in der Bedienungsanleitung stehen!
    Für was haben sie es dann eingebaut??? Rolling Eyes
    Hi Christian,
    also das glaub ich nun wirklich nicht. Wenn die Funktion drin ist, dann darf die auch genutzt werden. Garantie wird deshalb nicht erlöschen.
    Gruss,
    Nick
  • Oder ist das nur in der Schweiz so??? Evil or Very Mad
    Natürlich nicht bei einmaliger benützung und wahrscheinlich auch nicht auf solche dinge wie Garantie gegen Durchrostung... Es geht um die Garantie der Antriebseinheit... Gehört bei Einer Schweizer Automobilsendung (ja das giebt es).
    Oder war das noch beim SMG1 und ist heute beim SMG2 kein Problem mehr?
    War das SMG1 ein 5Gang Getriebe?
