Denso Zündkerzen
It could look worse! Apart from being really foul, some guy over-reved his engine in 2nd and 3rd and his OEM plug look like this!
It looks like the plug melted.....McHeizer: Your plugs are brand new man!
Original von super_2000
It looks like the plug melted.....Hhm, Melted because of over-revs?
Looks more like a mechanical demage, or?
But in that case the hammered spark plug is the least disease...There must be more broken inside.Markus
I've also read the story in s2ki.com, Fran.
The guy shifted from 3rd Gear into 2nd instead of 4th! A valve has broken and destroyed the Head and the Piston. But it wasnt the fault of the sparks (at least not in this case). And in the picture the plugs aren't Denso. -
Original von S-enna_2000
A bit of both I would say. Your right though, the plugs are least to worry about because now the broken bits are in the engine. Ouch!
Original von bpaspi
The guy shifted from 3rd Gear into 2nd instead of 4th! A valve has broken and destroyed the Head and the Piston. But it wasnt the fault of the sparks (at least not in this case). And in the picture the plugs aren't Denso.I have almost 50k on my S, I will check my plugs this weekend and plus I was driving hard on the NS the last weeks. I may try the Denso IK22 for a change.....
Gruss!
So, does my NGK plug look ok for 49,000km? All 4 of them were similar.
Will there be any noticeable difference if I would use a set of Denso's?
Never change a winning Team!
They look absolut good -means your engine is running good and the sparks are the right ones.
Use the same NGK's again -my recommendation!
Original von bpaspi
Alright, sounds good to me.
Cheers!
habe heute mal meine zünkerzen überprüft!
Und was sehen meine augen da!! alle durch, der weiße keramik körper ist bei allen 4 kerzen schwarz
Da ich die kerzen noch nie gewechselt habe, erstaunte ich als ich den namen Denso gesehen habe. Denso PK22 oder so. ich dachte NGK is OEM???? die zündspulen sind auch von denso!! ist das so richtig???
Original von McHeizer
dazu muss man sagen:
Honda hat ja als OEM Kerze zwei Typen freigegeben: jew einen Typ NGK u Denso.
Nur ist OEM ein anderer Typ (PK22) als dieser hier (IK24 ->kälter) -
