  3. ALLGEMEIN
  4. International
Blitz : JDM AP1
  • Blitz
  • 15. September 2009 um 18:51
  • Blitz
    Dauernd
    Hi Leute,
    I'm going to write in English, I do know quite a bit of the German language but I don't know all technical terms in German , so untill then I'll write in English.
    Specs
    Backyard Special lowered seatrails
    Spoon Drop-in Filter
    Spoon LSD
    Spoon Final Gear
    Spoon suspension kit fully adjustable
    Spoon front cross beam bar
    Spoon proppeler shaft
    Spoon brake lines
    Spoon brake rotors
    Spoon brake pads
    Amuse Powerhouse speedlimit delimiter
    ASM Autobacs GT Towerbar
    ASM Autobacs driveshaftspacers
    [Blockierte Grafik: http://i186.photobucket.com/albums/x11/Caine284/JDMAP1.jpg]
    [Blockierte Grafik: http://i186.photobucket.com/albums/x11/Caine284/DSC03539.jpg]
    J's Style 4-2-1 header with 2,5" collector and titanium finish
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03951.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03952.jpg]
    Spoon valvecover
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03953.jpg]
    Had the S2000 for one week and wanted to know what the HP and torque was at the moment, so dynoday!
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/s2000-7.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/s2000-6.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/s2000-3.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/s2000-2.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/s2000-1.jpg]
    Results
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DYNO1.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DYNO2.jpg]
    Standard the JDM AP1 has got 250hp, I made this run on octane 98. So I guess with octane 100 and finetuning I can get to the 250hp without enginemodifications 8)
    Also noticed that the speedometer was limited to 180 km/h, so changed that immidiately!
    2 weeks after that the second test @ Nürburgring!
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC_0475.jpg]
    My low position seatrails wasn't installed at the moment as you can see :P
    I will build the S2000 for circuit use but it will also be a democar for our shop.
    This car already has a history on the Japanese tracks and has been serviced @ the Type One Garage in Japan.
    They also installed all the Spoon Sports parts.
    For the coming winter I have planned to install the OEM hardtop which has just been painted, also the ARC Super Induction Box with ARC Intake Chamber.
    I have ordered quite some parts @ our partner ASM Autobacs Japan;
    - ASM Autobacs Floor Reinforcement bar
    - ASM Autobacs Inner Reinforcement braces
    - ASM Autobacs Rear Tower bar
    - ASM Autobacs Rear Lower Arm bar GT07
    - ASM Autobacs Front Lower Arm bar
    Still thinking what to do with the brakes and swaybars
    My second car is a '96 EJ9 Honda Civic 1.4
    [Blockierte Grafik: http://i186.photobucket.com/albums/x11/Caine284/DSC03515.jpg]
    [Blockierte Grafik: http://i186.photobucket.com/albums/x11/Caine284/DSC03516.jpg]
    Firs was Dark Green and it was resprayed in Midori Green (OEM Honda) last year.
    The plans for this winter are:
    Motorisch:
    Frankenstein engine ('99 JDM CRV - '99 98 spec JDM B18C-R)
    98 spec S80 LSD gearbox
    Brian Crower Camshafts
    Brian Crower valves
    Brian Crower valve springs
    Brian Crower retainers
    Bisimoto header based on enginespecs with 2,5 inch collector
    Bisimoto cam gears
    2,5 inch APE high flow cat
    2,5 inch cat-back
    ARP blots
    IM will be portmatched to 68mm
    68 mm throttlebody
    Custom intake met velocity stack filter
    Hasport mounts
    Hasport axles
    ACT Street disk kit (not 100% sure)
    ACT lightweight flywheel
    Mishimoto full size radiator with full size scrout
    Bekerom Tuning ECU
    NGK sparkplugs and sparkplugcabels
    Chasebays loom
    Gelbattery incl. relocation kit
    Oil filter relocation kit
    More updates will follow shortly!
    [Blockierte Grafik: http://i186.photobucket.com/albums/x11/Caine284/logo.gif]
    • Zitieren
  • Igor
    • 15. September 2009 um 19:23
    Nice project, keeps us updated!
    Igor
    • Zitieren
  • Integra
    • 15. September 2009 um 19:41
    Yellow S2K :thumbup:
    • Zitieren
  • McHeizer
    • 15. September 2009 um 20:35
    I love the choice of performance parts :thumbup:
    keep us posted!
    and see you at the ring someday :twisted:
    • Zitieren
  • super_2000
    • 15. September 2009 um 21:47
    • #5
    Sweet! I too like the choice of parts, especially the rims! :D :thumbup: Regarding the picture of the S with the Work emotions mounted, do you have wheel spacers on the rear axle?
    I'm looking forward to the updates!
    BrumBrum...VTEC
    • Zitieren
  • Tomcat
    Oberfan in Ausbildung
    • 15. September 2009 um 22:18
    • #6
    Original von Blitz
    So no use in asking, whether RHD doesn't bother you in RHside traffic... ;)
    veni - vidi - vtec!
    Einmal editiert, zuletzt von Tomcat (15. September 2009 um 22:18)
    • Zitieren
  • S2000pw
    • 16. September 2009 um 14:10
    • #7
    Great parts! :thumbup:
    • Zitieren
  • Blitz
    Dauernd
    • 16. September 2009 um 17:53
    • #8
    Original von super_2000
    No, it's without spacers with high J and lower ET/Offset you can get that result ;)
    • Zitieren
  • Blitz
    Dauernd
    • 16. September 2009 um 17:56
    • #9
    Original von Tomcat
    Not at all, to be honest I actually prefer RHD, I have also driven a JDM DC2 so I already had quite some experience ;)
    • Zitieren
  • McHeizer
    • 16. September 2009 um 17:59
    • #10
    why do you prefer it?
    I mean what are the advantages over LHD?
    • Zitieren
  • Blitz
    Dauernd
    • 16. September 2009 um 18:04
    • #11
    Today I picked up my set of quite rare wheels, I had these painted in a custom flat black colour with a polished lip.
    Volk EVO4
    2x 18x7,5J ET45 5x114,3
    2x 18x8,5J ET50 5x114,3
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03965.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03967.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03968.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC03966.jpg]
    But believe it or not, just after I picked up the wheels I got a call from our Japanese agent. They have found a set of Spoon SW388 8)
    So I guess these wheels will be up for sale.......
    • Zitieren
  • Igor
    • 16. September 2009 um 18:23
    • #12
    Keep the Volks please, Spoon SW388 suck!
    • Zitieren
  • super_2000
    • 16. September 2009 um 21:06
    • #13
    Original von Igor
    I agree, the Spoon rims look cheap and ugly! The Volk EVO4 look pretty nice.
    BrumBrum...VTEC
    • Zitieren
  • Blitz
    Dauernd
    • 17. September 2009 um 08:57
    • #14
    Well I am thinking about getting the Spoon wheels, perhaps for the trackdays.
    I do have a wheelfetish :roll: so expect to see several sets a year!
    • Zitieren
  • McHeizer
    • 17. September 2009 um 10:28
    • #15
    Original von Blitz
    it's like women with shoes, right ;)
    I actually like the SW388, especially on a track car!
    why do you prefer a RHD car, what's the advantage?
    • Zitieren
  • Blitz
    Dauernd
    • 17. September 2009 um 10:42
    • #16
    Hahaha that's right, what women have with shoes I have with wheels :lol:
    I prefer RHD because then I have better overview in the daily traffic.
    For instance; when I want to pass somebody on the road and I have to look over my left shoulder I have way more sight.
    Also ordered the ARC Super Induction Box with ARC Super Intake Chamber. We're going to test if we can win some HP with this kit.
    There are lot's of opinions about this kit, so we're going to test it out and see what it does :thumbup:
    [Blockierte Grafik: http://i49.photobucket.com/albums/f295/miata2nv/pics%20with%20friends/HCI%20photo%20shoot/nightengine.jpg]
    • Zitieren
  • McHeizer
    • 17. September 2009 um 12:44
    • #17
    OK
    let us know how it works.
    my opinion (w/o reading anything about it) from simply looking at it:
    - the intake chamber -> some torque gains
    - induction box ->hot air/ less air
    - overall more weight
    • Zitieren
  • Blitz
    Dauernd
    • 5. Oktober 2009 um 14:56
    • #18
    Update S2000;
    I have ordered a Spoon Aluminium Fin. Diff. case NTS so I will enlarge the original LSD oiltank from 700 cc till 2200 cc to keep the oil longer cool on the track and have an optimal working of the Spoon LSD.
    I have sold the Volk wheels :blush: I have tried them on the S but I thought it didn't look that amazing......
    Update Civic;
    Last week we have also installed a Kaaz LSD in the 98 spec B18C-R gearbox and there also seem to be another Final drive in the gearbox :_? let's see if we can find out what type of final gear it is.
    • Zitieren
  • McHeizer
    • 8. Oktober 2009 um 13:57
    • #19
    great upgrade :thumbup:
    keep them coming!
    • Zitieren
  • Blitz
    Dauernd
    • 30. November 2009 um 11:49
    • #20
    I had some spare time left this weekend so I installed the ASM Autobacs GT Tower bar and the ARC Super Intake!
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC029211600x1200.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC029551600x1200.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC029511600x1200.jpg]
    [Blockierte Grafik: http://i568.photobucket.com/albums/ss122/RisingSunMalden/DSC029531600x1200.jpg]
    The stifness which the ASM bar gives is incredible, it was quite a tough job getting it installed but the endresult is superb.
    Installing the ARC intake was a piece of cake.
    Soon we will make a new dyno and i'm curious to see what this intake brings.
    • Zitieren
  • Erfahrungen HKS Krümmer
    • hikaito
    • 18. März 2020 um 12:54
    • Tuning
  • Einer weniger - tiefe Trauer - Ärger mit Wiederbeschaffungswert
    • Maxx2000
    • 16. September 2020 um 13:10
    • S2000
  • (Saison-)Ende für meinen S...
    • Maddy
    • 13. Oktober 2020 um 18:10
    • S2000
  • Fahrzeug oder Stehzeug?
    • messi
    • 6. Oktober 2020 um 15:01
    • S2000
  • CO2.
    • steve hislop
    • 30. Januar 2020 um 14:19
    • Bistro
  • 3 Mitglieder (davon 1 unsichtbar) und 2.795 Besucher
  • Diablo70
  • vader87
