Sammel-Thread: Motor-Öl-Wissen
  • Teil 2:
    Post #34:
    Now a couple of things to keep in mind,
    -Yes, the tests were conducted on Mobil 1 EP [Extended Performance] oil.
    -The changeover [to Group III base stocks] has been gradual, it started with some grades and gradually included others.
    - Yes, Mobil still claims that their M1 is fully synthetic. No one is arguing that the oil is not fully synthetic going by the current legal nomenclature. The problem arose when Castrol won the ability to call Grp III hydrocracked dino oil a 'synthetic'. Mobil was the company that complained, and when the decision was made to allow it, Mobil saw the opportunity to change their formulations making them cheaper to produce, while retaining the label and maintaining the price.
    - Try contacting Mobil and outright asking them "Does Mobil 1 contain Grp III hydrocracked base stocks?" and they will not answer. Go ahead, give it a shot. They're reply is that Mobil 1 is a full synthetic. Well that wasn't the question now was it? considering that they can legally call Grp II hydrocracked basestocks a 'synthetic'. doesn't change the fact that although the hydrocracked oils are now almost as good as some PAO basestocks, they are stil not comparable under extreme conditions (and even PAO's don't hold up as well as ester based oils under extreme conditions).
    - There is conjecture that the change to Grp III hydroocracked basestock is now being reversed and is being reverted to PAO, occurring initially only because Mobil 1 had a shortage of available PAO basestock and chose to take advantage of the legal ability to continue calling the oil a full synthetic wth the Grp III stock. This is however, conjecture at this point, and even if it's true, I still personally choose not to support a company that changed it's formulation to something cheaper to produce while sacrificing performance under extreme conditions without disclosing this to their customers and retaining the premium pricing and increasing profit margins.
    I'm not saying Mobil 1 is a crappy oil for streetcars. For most cars, even dino is fine. But I push my car hard, and when I'm doing that, I'd rather know that I'm using something that provides great protection. Roadcoursing falls under the category of extreme use. So does dragracing with significantly more HP than stock. The fact that Mobil 1 has shown to shear has removed it from my list of reliiable oils. If I wanted a 20 weight oil, I'd have chosen a stable 20 weight oil, but I don't think 20 weight provides adequate protection under sustained conditions on a roadcourse.
    Post #35:
    Forgot about that. I haven't actually used/tested Amsoil myself so I can't say. I've always heard it's a good oil. Never heard anyone say anything bad about it, although there are those who say that Amsoil tends to make their oil out to be much better than it is. Doesn't change the fact that it's still considered a good oil though, but I don't know how well it holds up under extreme use/conditions. The UOA's I've seen on Amsoil were pretty good, but they were all on daily driver unmodded cars. Haven't seen any UOA's on modded cars or ones that see the track, and one of the things about their VOA's is that Amsoil (and Mobil 1) have no moly in their oils.
    Moly is a great friction modifier and a very good EP additive. Somewhere in another post I detailed how moly works in the engine. Motul 300V has the highest levels of moly I've ever seen in a gasoline vehicle motor oil. Redline's moly levels are close. M1 and Amsoil have none and Royal Purple has about 1/5 the moly levels of Redline. I don't use Royal Purple motor oils because they tend to shear too. Amsoil is pretty shear stable so if it's cheaper than Redline, I'd say stick with it.
    BTW, one thing I forgot to add for those thinking of switching to Redline or Motul 300V. Because these oils are sold as racing oils they do not have to comply with the API's max levels of phosphates. The phosphate content has been reduced for all API certified oils because high levels can lead to decreased life of the catalytic converters. The phosphates however, are in the form of ZDDP (Zinc Dialkyl-Dithio-Phosphate) which is an EP/AW additive which comes into play under extreme conditions. The engineers I spoke to said that ZDDP actually comes into play under very high forces.
    ZDDP is a boundary lubricant meaning it comes into play when the oil film is squeezed out under very high pressure (most commonly between the cams and rollers and the rings and cylinders). More ZDDP doesn't mean more protection per se, but longer protection under those conditions. The important part is that ZDDP (and moly which is also a boundary lubricant) can come into play betwen the bearings and journals near redline (due to the very high reciprocating forces) and also with any engine that is making anywhere in the 200+ crank HP/liter. All our modded cars making 450awhp or more fall into this category.
    Because these 2 oils aren't API regulated (being marketed as race oils), they don't follow the lowered phospate limits and have high ZDDP levels (good for extreme use), BUT they can potentially kill your catalytic converters quicker. This is not really a problem if you aren't burning oil (or drive a racecar without cats).
    Post #40:
    The lowest prices I've found for 300V here were $25.75 per 2 liter can shipped if you order over $100. since we need 3 cans, it was easier to order 4 or more to get the free shipping.
    As far as how moly works, I don't know where my post was but here's a quick rundown.
    Moly bonds with any metallic surface it's exposed to especially where there's some heat and pressure involved. It fills in surface asperities (roughness) and creates a very, very smooth surface reducing friction. It also acts somewhat similar to graphite in the sense that the molecules shingle. One way folks have described the way moly works is like sliding something over a bunch of playing cards. The cards slide over each other creating low friction.
    Moly however bonds pretty strongly to the metal. In fact some folks testing it have said that after moly bonds to the metal surface, the only real way to get it off is to grind it off. I had my bearings dry-film moly coated, but the coaters didn't take precautions to avoid coating the bearing ends (at least they made sure not to coat the bearings backs). I had to scrape the moly coating off the bearings ends to avoid affecting the bearing crush specs and after scraping the coating off (only some of the bearings had the overspray), the ends were left a dull gray and there was no way to change that (since I sure as heck wasn't going to grind the bearing ends).
    Moly's bond and friction modifier characteristics can withstand pressures up to 500,000 psi. Althugh this sounds like the Prolong/Zmax etc. BS, the company conducted some tests on the effectiveness of moly (to see if they wanted to use it on their equipment) had a small 3HP engine coated with moly. It ran with no lubrication at all, and when they tore the engine apart, it showed practically no wear.
    One of the newer EP/FM/AW additives is Boron. You'll see it in some oils. It works in a similar fashion to Moly and once it bonds to the surface, it supposedly lasts for a good long time. Not sure if it will withstand the pressures moly is good for
    Post #44:
    ""Originally Posted by Ondontii: Cant you get moly additives by themselves?""
    Yep, but not all moly is created equal. Most of the moly additives that you buy separately in small amounts to add to the oil is moly disulfide. while moly disulfide is a good lubricant, the difficulty is with keeping the stuff in suspension so it gets where it needs to go. Most often, it will seperate out of the oil before it has a chance to coat the parts that need it. The other problem is the size. A lot of the moly additives have particulate sizes too large and they get trapped in the filter which = not getting where it's needed and possibily clogging the filter prematurely. Most of the good oils seem to be using organo-form moly's like Moly Dithiocarbamate.
    There are probably some moly add packs that are decent but I don't know which ones those would be. It's generally better to just get a better formulated oil to start with.
    Post #46:
    [Royal Purple] 10w40 sheared to a 30 weight by the time a UOA was done at 2500 miles. since most oils that shear tend to shear fairly quickly (M1 0w40 will shear within 1000 miles), who knows when it begins shearing? In one of the links to earlier posts I made that Novot posted, I mentioned that under extreme conditions (track use at high temps and repeated redline especially if the car is modded for more HP) it's possible for an oil to start shearing within a couple of hot laps (wonder why some folks can sping a bearing within a few laps of Road America?). Once an oil has sheared, the viscosity loss is permanent.
    Einmal editiert, zuletzt von MUGEN_S2K (14. März 2015 um 16:40)
  • Teil 3:
    Post #57:
    In a perfect world, a 0w20 or 0w30 oil would be great. Unfortunately, chemistry hasn't reached that point yet when it comes to oils.
    Here's why I don't use a 0wXX
    a) The greater the viscosity spread in an oil, the greater the likelihood of VII's to provide that spread and hence the greater the chance that the oil will shear in hard use, so anything wider than a 0w20-0w30 has a greater chance of shearing under hard use and for hard use in our engines a 40weight fits best.
    b) If Redline/Motul made a 0w40 that didn't shear, I'd be all over it, but they know that their oils will likely be pushed hard so they don't even make one with that spread because it'ld probably shear at the track. Mobil 1's 0w40 shears. Redline's 5w40 has also shown to shear under very hard use, the 10w40 though, holds up pretty well.
    c) Oils don't lubricate as well when cold because they don't flow anywhere near as well as when they reach proper operating temps. Thge lack of sufficient flow is one reason why you need to avoid leadfoot till the engine's warmed up. I try to limit my rpm's to 3000 rpm until the car has warmed up (takes about 10-15 minutes of driving). Definitely not over 4000 rpm for the first 15 minutes.
    d) In addition, if the car has been sitting for a while, some parts may be dry for the first few moments of startup since the oil has drained into the sump. This is what the majority of 'normal' engine wear is attributed to. The first few moments during and after startup. That's another reason why I like ester-based oils. They have an inherent polarity that causes them to stick to surfaces. They will maintain an oil film better than dino and PAO's providing that little bit of help till oil pressure gets up and oil is actually flowing. A 10w ester is subjectively better on cold startup than a PAO and definitely better than a dino.
    So why a 10w40 and not 10w30? Well, it's all about useage, temps and clearances. If it's just for daily driving, 10w30 is fine, but if you're going to push the car, the resulting higher oil temps would be better served with a higher HTHS. Why a 40 weight and not 50 or higher? With my bearing clearances of 0.0018 (and any 6G72 still within upper factory specs), a 50 weight won't flow well enough at higher rpms. A 40weight with Redline and Motul's HTHS at temps when pushed protects better than a 30 weight or dino 50 weight and will flow fine. Now if my bearing clearances were something in the 0.0008 - 0.0012 range, I might actually try one of the 0w30 options (or maybe even a 0w20).
    See, I talked to one of the head tribologists (oil engineers) who developed Motul 300V about the 6G72 with my clearances + redline of 8300 rpm + e16g power ~700crank HP (~mid-500 awhp) roadcourse use and I not only wanted to know what they recommended for the application (as in viscosity), I also like to know why.
    If anyone here's a BITOG'er, you might know who Terry Dyson is. Well, I've been talking to him about a new oil he's helped a small independent company develop. A 5w40 that has shown to be incredibly resistant to shear and especially to fuel dilution. It appears that this new oil has better shear resistance than 300V, which in itself is extremely shear resistant. The question is whether this oil shows better resistance to mechanical shear or chemical shear? Motul 300V and Redline are both very good with chemical shear, but I'm not sure how well they handle chemical shear caused by fuel dilution. This new oil certainly looks to be a very good option for anyone with fuel dilution problems (could be a good oil to use while tuning a newly HP modded car), but I haven't seen any concrete results with very high HP turbo applications, so we'll see.
    Post #69:
    But to answer your question, if daily driving is the purpose, then there are plenty of good oils available out there that will get the job done at much cheaper cost. In fact, for just daily driving and folks who don't ever really push their cars, Pennzoil Platinum would be a good option, especially when you can find it on a buy-one-get-one-free sale.
    The reason I bother to spend the extra for Redline/Motul 300V is because I actually push my car hard. I can tell you that one engine rebuild will easily blow away all the potential 'savings' from using a less expensive oil. But I've stated in other threads (can't remember if I've stated it in this one), if you drive like Miss Daisy is in the passenger seat, feel free to use whatever oil you wish.
    ***P.S. edited to add*** forgot to mention. As far as data and evidence correlating oil use and engine wear goes, that exactly what UOA's are for. UOA = Used Oil Analysis. There are more than a few folks on 3si who use the services of Blackstone Labs, however, if you have the money for it and are actually interested enough, try Terry Dyson's analysis directly. Terry is well-known in the industry and his analyses of oils can potentially help save your car. They can also tell you if a particular oil is performing better in your car or worse, creating more wear or reducing it etc. One thing to remember is that it may take anywhere up to 2-3 OCI's (oil change intervals) before the new oil stabilizes the chemistry in the engine to get an accurate picture of its performance. Redline is one of the quirky oils in this respect. Folks who have no patience should stay away from having Redline analyzed.
    When switching to Redline from a different oil (especially a dino), a UOA within the first couple of OCI''s has a tendency to show increased levels of wear metals. This trend generally dissapears after about the 3rd-4th OCI. The speculation is that the polarity of the ester based oil cleans better than other oils (including PAO's which are not polarized) and the increased wear metals are from the removal of crud in your engine, because folks who continue using it find that after the 3rd or 4th OCI, Redline starts showing very good results with low wear metals.
    The other distinct possibility is the additive pack in Redline. Redline and Motul 300V are two of the very few oil available that have a very high molybdenum content (and very high ZDDP levels too). Moly is both a FM (friction modifier) and an EP(extreme pressure)/AW(anti wear) ingredient, some of these additives don't work well until they replace the previous oil's chemistry (especially the ones that coat metal parts. You can find more of my posts explaning how moly works in oils. Until the new chemistry and add pack has compleetely replaced the old, it may be possible for the engine to actually experienced slightly increased wear. Keep in mind, in UOA's this is measured in ppm (parts per million). Not something you can see with the naked eye or feel between your fingers. By the time you can see or feel material in your old oil, you're already in trouble.
    Quote:
    Originally Posted by brutten
    Questions for us "daily drivers"... Is Redline oil 100% ester concentration like 300V or a blend? Can 100% ester oils cause increased wear on seals ?
    Redline is not 100% ester. It has about 14% (or was it 18%?) PAO for exactly that reason. Esters generally cause seal swell (not wear), while PAO's usually cause seal shrinkage (mineral/dino usually causes seal swell, which is why some folks get leaks switching from dino to some PAO's), so in the case of Redline they add a little PAO to balance it. There are other ways to manage it though.
    There are additives that can be used to combat both seal swell and/or seal shrinkage. In fact, there are certain esters that cause shrinkage and not swell. IIRC, this is one of the reasons why 300V can use a full ester formula, by combining different esters with different properties offering specific advantages in different areas. That's one of the interesting things about ester chemistry, they keep improving it and can practically tailor make a specific ester with the characteristics desired and ester-based chemistry is completey renewable, it's not based off mineral oils.
  • Teil 4 (letzte :D):
    Post #117:
    Yes, Red Line now has 0w40. They have a 0w30 too. The problem is still that at this time, the industry is not capable of formulating anything with a viscosity spread that high without VII's. NO company has been able to formulate a 0w30 or 0w40 without VII's because there is no basestock that has the ability to maintain viscosity like that. I think there may be some 0w20 formulations that have little to no VII's but we don't drive Hondas.
    There is some decent info in that [Ferrarichat] article (and if you read through the thread, you'd see that the link has already been posted AS IN THE ABSOLUTE FIRST LINE OF THE FIRST POST IN THE THREAD), HOWEVER, the info is not complete. The only real information you can garner from that link is why you should try to run a lighter 'cold viscosity' oil. Reading that post could lead you to believe that running a 0w20 or 0w30/40 oil is the best idea ever, and it would be incorrect.
    As I've mentioned, different engines stress motor oils differently. Some engines (notably Honda and Toyota's grocery-getters) put very little stress on the oil. The engines are designed with very good tolerances and you can potentially run a good oil out to 15,000 miles or more before changing it.
    I don't care what oil you're using, I sure as heck wouldn't run ANY oil out to 15,000 miles in a VR4 unless you really only cruise on the highway, never get into boost, never rev the engine past 3500-4000rpm, make sure that there are absolutely no leaks in the intake tract, ensure that you have the absolute best air filter (NOT K&N), make sure that your rings are tight and you're getting minimal blowby, not running rich or getting fuel dilution, no leaks in the cooling system, etc. etc. etc..... and then I STILL wouldn't run the oil 15,000 miles.
    I HAVE (with uoa) run Red Line 10w40 to 7500 miles before changing it out and the uoa indicated that I could potentially run it out longer, perhaps to even 10,000, but only if I didn't track the car. The wear metals were still low enough, and the TBN sufficient to run it further, but they were at the level where I wouldn't want to be pushing the car too hard for that added 2500 miles on that oil.
    And as I've mentioned, Mobil1 0w40 sheared from less than 1000 miles of street driving (zero track time). I won't touch that stuff again with a ten-foot pole. Yet, it works quite well in some other platforms and engines and they can run it for 7000 - 12,000 miles.
    Likewise, Royal Purple 10w40 sheared to a 30 weight in ~1200-1600 miles with ONE track trip) and yet, some folks LOVE that stuff in their cars.
    See what I mean?
    Most regular folks just go, "Eh... I don't know what I put in the car, whatever they sell me at Jiffy Lube". Even most enthusiast folks just go, "Yeah, I use XXX because I heard it's really good". So few folks bother to actually check to see if what's good in other engines is actually good in ours.
    Post #130:
    Keep in mind that although zinc levels are important for most oils (phosphorus levels are simply as a carrier for zinc in the form of zinc dialkyldithiophosphate aka zddp) , some tribologists have been using molybdenum as a boundary lubricant.
    Red Line uses it and so does Motul. In fact Motul has the highest moly levels I've ever seen in an oil available for street vehicles. If I didn't write about it in this thread, you can search my posts about moly's properties as a boundary lubricant and EP and FM additive.
    Post #138:
    Even at 90+f ambient temps, Red Line or Motul 10w40 is a good viscosity. Bear in mind that esters are very resistant to heat and at high temps, a 40 weight ester base holds viscosity better than a 50 weight dino.
    The only reasons to use a 50 weight ester are if you'll be running really hard at high temps (endurance racing at 90+f) or if you have very loose bearing clearances (In which case you really should replace the bearings).
    BTW, 3k GT driver,
    Regarding Mobil's blurb about synthetic base stocks, the whole motor oil community uproar about Mobil 1 was because they began using Grp III hydrocracked base stocks without changing their prices or marketing.
    Castrol was the company that began doing that. Mobil filed with the board that governs advertising, claiming that Castrol was falsely advertising their oils as synthetic when they weren't truly synthetic. After considerations, it was deemed that hydrocracked oils were processed enough to allow the synthetic moniker and Castrol could continue to advertise their oils as full synthetic.
    Since Grp iii cracked base stock is far cheaper than the PAO base Mobil had been using and the board had deemed it OK to call it synthetic, when Mobil had a PAO shortage, they began using Grp iii oils for the base stocks. Since their costs lowered dramatically, they kept at it,... while keeping their advertising AND pricing the same. More profit.
    I don't know if they ever changed back to a full PAO base after the uproar, but i don't believe so. After all, it was only a relatively small section who heard about it compared to the clueless masses. Last time I looked, the temp specs still indicated the lower temp ranges indicative of Grp iii. PAO oils have very good low temp specs.
    Doesn't matter to me ever since I saw how fast Mobil 1 0w40 sheared in my car from just street driving. Their stuff won't ever go in my car(s) again.
    Post #143:
    There are other good oils of course, but if you get Red Line or 300V you won't have to worry/wonder about the oil. Just stay away from Mobil 1 0w40 (sheared in about 1000 miles of street driving ) and I would avoid Royal Purple 10w40 too, (sheared in about 1200 miles, with a couple hundred miles of track use).
    Einmal editiert, zuletzt von MUGEN_S2K (14. März 2015 um 16:41)
  • hi eddy,
    da hast ja viel reingeballert und ich habe manche stellen ausführlich gelesen, andere weniger.
    falls du alles gelesen hast, kannst du ja locker antworten :)
    also:
    1.) witzig ist, dass nach deren meinung eine öldiskussion bei motoren von honda und toyota hinfällig wäre, da die lagerspiele und andere bauteiltoleranzen sehr groß seien.
    das weiß ich nicht. weiß das jemand aus sicherer quelle? vielleicht labern die auch nur in diesem fourm :roll:
    2.) generell finde ich: machen die sich schon einen seeeeeehr großen kopf um das thema öl.
    da sind wir hier ja ein witz dagegen.
    ZUM EIGENTLICHEN THEMA:
    3.) aussage: große spreizung des viskosität = schlecht --> schonmal gehört, aber ob das 100% zutrifft?
    4.) nach denen: alles außer motul und redline = schlecht ? --> hhhhmm :-|
    5.) hatten esteröle nicht den nachteil, dass sie DEUTLICH früher gewechselt werden müssen als herkömmliche?
    eddy, du bist grad wohl tief in der materie drin und bist auch seither schon das motul gefahren, richtig?
    was sind deine schlüsse aus alldem für jetzt und die zukunft?
    ich war lange nicht mehr hier aktiv (sehr wenig zeit) und wollte heute Öl bestellen,
    deswegen bin ich aufmerksam gworden :)
    grüße Dome
    2003 Monza Red
    Foren-Thread zu meinem S2000
  • Hi Dome,
    das weiß ich nicht. weiß das jemand aus sicherer quelle? vielleicht labern die auch nur in diesem fourm Augen rollen
    Eigentlich genau das Gegenteil. Der F20C hat eher geringe Lagertoleranzen. Aus dem S2ki hab ich schnell die Angaben gegoogelt .0007 to .0016. (inch). Daher erwänt der auch das WENN er einen Honda Motor hätte, ein xxW30 Öl probieren würde. Er verwendet daher aber ein 10W40
    Ist doch hier nicht anders. Oder kennst hier einen Öl-Thread wo nur eine Seite lang ist :D
    Was heißt schlecht, es ist halt ein Kompromiss. Als Ausgangsbasis dient ein vollsynthetisches 10W40. Um daraus ein 5W40 oder 0W40 zu machen kommen die Viscosity Index Improvers ins Spiel. Der Nachteil dieser ist eben die geringere Scherstabilität.
    4.) nach denen: alles außer motul und redline = schlecht ? --> hhhhmm Neutral
    Nicht gleich schlecht sondern weniger scher-stabil. Liegt daran das die anderen keine Ester basierende Öle bzw. keine Ester Zusätze haben. Motul wirbt bei seinen Ölen, vor allem 300v Reihe, damit und Redline anscheinend ein 14% Zusatz im Öl.
    Ist auch kein Geheimnis. Motul selbst vermarktet es auch nicht als Longlife-Öl sondern eher als Racing-Öl wo unter stresserigen Bedingungen arbeiten muss. Daher ist die Formulierung auch anders. Das Öl kann natürlich auch als daily drive genutzt werden. Das Gerücht das keine Weichmacher, wegen Dichtungen ect. im Öl sind ist ein Gerücht, unzähliche Öl-Analysen beweisen genau das Gegenteil. Die 300V Öle haben eben keine spezifische Herstellerfreigabe was viele zurückschreckt. Die kürzeren Wechselintervalle beruhen auch immer auf den vorgesehenen Einsatz. Daher wenn damit immer auf dem Track bist, ist wohl nach ungefähr 7-10000km ein Wechsel empfehlenswert. Bei einem Daily Drive kann, je nach Belastung, der Wechselintervall verlängert werden z.B. 15000km.
    Aber generell wird dir hier jeder empfehlen nach/vor dem Track frisches Öl einzufüllen, unabhängig der Marke.
    Ich hab bis jetzt aus der Motul 300V Reihe das 5W40, 10W40 gefahren. Jedesmal im März eingefüllt und im November bzw. zu Beginn der neuen Saison das Öl gewechselt. Und kann mich soweit nicht beklagen. Kein Ölverbrauch or what so ever :nod:
    Diese Saison kommt das 5W30 Power Racing rein. Den Grund hierfür habe ich ein hier oder in einem anderen Ölthread schon mal erwänt. Glaube das war beim Thema 10W60 oder so.
    Stichwort hoher oil-pressure ist nicht gleich hoher oil-flow. Sollte sich das 5W30 hinsichtlich des Öldrucks deutlich schlechter verhalten wie die anderen, kommt es weider raus wobei ich da nicht so die bedenken habe.
    5 Mal editiert, zuletzt von MUGEN_S2K (16. März 2015 um 16:43)
  • Hallo Zusammen, ich habe das Thema Motul 300V Eignung und Merkmale bei Motul selbst angefragt. Hier die Antwort von Motul:
    Sehr geehrter Herr Band,
    vielen Dank für Ihr Interesse an unseren Produkten.
    300V Öle können problemlos im Honda S2000 eingesetzte werden.
    Wir empfehlen Ihnen 300V Power 5W40 (über Jahre im privaten S2000 gefahren)
    Das Öl kann bei Alltagseinsatz für bis zu 15.000 km Intervalle eingesetzt werden, bzw. spätestens einmal jährlich gewechelt werden (je nachdem was zuerst eintriftt)
    Verschleißschutz und vor allem Druckstabilität ist im Vergleich sehr viel höher als bei Standard-Synthetischen Ölen.
    Dichtungsverträglichkeiten sind zu 100% gegeben.
    Die weiteren Vorteile bei Esterölen:
    Exzellentes Fließverhalten; natürlich hoher Viskositätsindex (es werden nur im geringen Maße VI-Verbesserer benötigt);
    thermisch extrem stabil (für Öltemperaturen bis zu 150°C Dauerbelastung); geringer Verdampfungsverlust;
    hohe Polarität (Metallanhaftung) - dadurch besserer Verschleißschutz, vor allem auch beim Kaltstart !
    Mit freundlichen Grüßen
    MOTUL Deutschland GmbH
    Technik-Beratung
    E-Mail technik-beratung@motul.de
    Internet https://s2k.de/www.motul.de
    Facebook https://s2k.de/www.facebook.com/motul.de
    MOTUL Deutschland GmbH, Kölner Straße 263, 51149 Köln
    Amtsgericht Köln HRB 11609, Geschäftsführer: Martin Klein, Olivier Montange
    Stock 2009, Moonrock/Braun, Supersprint, 100 Zeller, Domstrebe, Kumho 36, Motul 300V 10W40
  • DANKE eddy + andy!
    klingt alles super.
    wenn dann würde ich auch mal das 300V 5w40 probieren.
    ich hätte nie gedacht, dass es sich so seltsam anfühlen könne, wenn man mit dem gedanken
    spielt, ein anderes öl zu testen :lol:
    so muss es sich anfühlen, das kind später zu nem anderen kinderarzt zu geben oder den
    babysitter zu wechseln :D
    eddy: würdest du mir bitte eine günstige (oder gar DIE günstigste :)) quelle für das 300v verraten? kostet ja doch ne stange kneten!
    ich wechsle bisher immer am 1. april das öl und würde aus "komfort"gründen auch gern weiterhin so tun. gibt es irgendwelche einschränkungen bei dem öl bezüglich standzeit von 5 monaten?
    also wird das eher schlecht als konventionelles öl?
    korrosionsadditive ähnlich vorhanden? weil wäre ja klasse, wenn das ja zusätzlich auch noch
    besser haftet, wenn es dann auch besser konserviert.
    wäre es aggressiver, wäre das haften auf dauer ja eher schlecht ;)
    ps: die aussagen "kein ölverbrauch" fand ich schon immer weniger zielführend bei einer öldiskussion. es ist nicht die aufgabe des öls verschlissene kolbenringe oder ventilschaftdichtungen grade zu biegen ;)
    also das zeichnet kein gutes öl aus. also lieber ein gutes öl mit verbrauch fahren als eine 200er visko ohne verbrauch (extrembeispiel) :)
    2003 Monza Red
    Einmal editiert, zuletzt von .: Dome :. (16. März 2015 um 20:12)
  • Ich schau jedes Jahr aufs Neue wo ich das Öl herbekomme. Das 5W30 hab ich diesmal von eBay über einen Öl-Händler bezogen.
    Wenn du das Öl nach der Standzeit gleich wechselst sollte das kein Problem sein, mach es nicht anders. Manch anderer kippt für den Winterschlaf frisches Öl rein nur um es dann zu Saison Beginn wieder zu wechseln :roll:
    Eine richtige Öl Analyse kann ich nicht vorweisen. So eine Auswertung hätte etwas mehr aussagekräftig. Wenn einer weiß wo man in D sowas machen kann wäre das schon mal ein Anfang. Solange musst du dich mit solchen Aussagen zufrieden geben :].
    Original von Tiedchen
    Fahre das 300V als 10W40 Chrono bzw 15W50 Competition jetzt seit anfang an im S und kann nicht klagen, so gut wie keinen Öl Verbrauch.
    Alle 10tkm wird spätestens gewechselt.
    Wo bewegst du deinen S damit ein 15W50 brauchst?
    Original von AndiS2000
    ....... habe mir das Motul 300V 5W40 wieder über Ebay bestellt 6L für 89 €. Bestellung bei Friken Racing
    Da hatte ich letztes Jahr auch bestellt :thumbup:
    Habe heute einen kompletten Öl-Wechsel (Getriebe, Motor, Diff.) gemacht und das Motul 300V 5W30 reingemacht.
    Auf dem Weg zur Werkstatt (ca. 40Km) hab ich öfters auf Öl-Temp und Öl-Druck geschaut um nachher einen Vergleich zum 5W30 zu haben. Vor dem Wechsel war das 10W40 Chrono von Motul drin.
    Interessant fand ich die Öl-Temp beim 5W30. Auf der selben Strecke (AB) hin hatte ich mit dem alten 10W40 bei Tempo 120-140km/h eine Öl-Temp von max. 105°C. Mit dem 5W30 hab ich die Temp bei selber Fahrweise nicht auf 100°C bekommen. Die Temp bewegte sich im Bereich 97-99°C :D.
    Beim Öl-Druck konnte ich keinen Unterscheid zum 10W40 erkennen zumindest keinen Nennenswerten. IMHO ist der Druck gleich geblieben.
    Soweit bin ich angenehm überrascht :nod:
    Original von etrate
    Mein Motor hat sich vom 5w/30 immer einen guten schluck gegönnt , das 5w/40 hingegen überhaupt nicht. Deshalb fahre ich nur noch das 40iger.
    Motul 300V?
  • Die ersten Jahre Alco und jetzt mequin das 30 iger war von der tanke die hatten nix anderes. War auch nur zum nachfüllen. Laut zettel hatte der 30 iger drinne gehabt. Und genau das hat im gut geschmeckt. Modul hatte ich noch nicht.
    Pure and Simply the S2000
    3 Mal editiert, zuletzt von etrate (13. Juli 2015 um 08:01)
  • Ich bin das Motul V300 5W30 jetzt 4500km gefahren und musste noch nichts nachfüllen.
  • Ich habe inzwischen mit dem 300V äusserst schlechte Erfahrungen gemacht. Allerdings war das in meinem Winterauto - einem Alfa 146 1.8TS-16V.
    Ich hatte im Frühjahr das erste Mal das 300V 15W40 reingekippt und nach ca. 1000km waren die Nocken und die Tassenstößel hin. 6 Stück waren platt.
    Mir ein völliges Rätsel - der Motor war davor ca. 30tkm problemlos gelaufen.
    Ich habe das 300V im Verdacht - vielleicht ist dieser Esterzusatz nichts für Hydrostößel. :?
    2 Mal editiert, zuletzt von bpaspi (13. Juli 2015 um 08:38)
    Original von bpaspi
    Ui... wenn Du ratlos bist, krieg ich bissl Angst. Zumal: Wenn son Hydrostößel seine Arbeit nicht macht, hört man das ja sogar als Laie deutlich. Wäre Dir doch nie entgangen.
    Hast Du mal überlegt, dem Motul-Support Bilder von Deinen defekten Teilen zu senden und die mal ganz offen zu fragen, was sie davon halten? Scheinen ja durchaus gesprächig zu sein. Obwohl ich auch nicht wirklich erwarte, dass der dann sagt: Na klar, das musste schief gehen. Aber fragen kostet ja nichts.
    Off Topic, aber dennoch mag ich fragen: Du fährst 15W in einem Winterauto? Stets warme Garage? Ist das nicht in der kalten Jahreszeit arg dick beim Kaltstart?
    2 Mal editiert, zuletzt von Los Eblos (13. Juli 2015 um 22:48)
  • Hi Bernd,
    Tippfehler? Es gibt kein 300V 15w40 oder?
    2003 Monza Red
